5931 Discussions
INTEGRATED USB BLASTER ON DK-DEV-10M50 doesn't work whereas regular JTAG does
MBiga
​Hi,
I would like to know if there is a way to reset/reprogram the integrated USB blaster integrated to this dev kit.
It worked once at the very beginning I use this card, but doesnt work anymore whereas jtag is okay.
Device is recognized by my computer on device manager, but no way to communicate...
Thank for your help.
AnandRaj_S_Intel
Please Check the sate of SW2.3.
Default switch state should be like sw2.4, sw2.3 should be ON & sw2.2 should be OFF.
Let me know if it works or if you need any further assistance.
Anand
MBiga
Dear Anand,
Thansk for your answer.
SW2 config I use is : 1 and 2 is OFF, 3 and 4 is ON.
Quartus Programmer failed and said "Selected on-board programming HW is disable" ​.
Dev kit software "Boardtestsystem.exe" said "No JTAG cable detected or selected" and LED1 is blinking when attempt to connect.
Issue not yet solved for the moment.
Any other idea ?
Thanks again
Fabrice
AnandRaj_S_Intel
Hi Fabrice,
SW2.3 need to be OFF for Board test system.
Kindly change the setting and try.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
MBiga
Anand,
So where we are now :
Config is SW2.4​ ON and others are OFF.
When I do an Auto-detect, FPGA is found so as VTAP10.
I had the file I have just compiled, and it fail to program .sof file.
.pof file is programmed the right way and FPGA works fine.
Board clock controller is okay, board testsystem as well.
After testing this feature, I try again with sof file which now seems to work...
Indead everything look okay.
Thanks for your support.
Fabrice
