Dear all,
Currently, I am testing the Triple Speed Ethernet (TSE) IP Core for a project. Now, I am very interested in purchasing the license whose Ordering Code is IP-TRIETHERNET for deployment purposes. However, I need to clarify a couple of questions:
1) If I purchase one license for the Stratix V FPGA, can I use the same license for different boards or is the license associated with only one specific Stratix V FPGA?
2) In the future we are planning to have a board with more than one physical ethernet interface. In this case, can we use a single license for instantiating several TSE IPs in the same design?
Looking forward to hearing from you soon.
Daniel Pestana.
Hello DanielGP,
Base on your inquiry, we have specific forum for these issues and I will be transferring this thread for faster response.
Please let us know when you can perform the test
Thank you.
Michael L.
Thank you for transferring the topic, Michael.
However, I have not received an answer yet from this topic, which is quite urgent for me.
Daniel Pestana.
Hi DanielGP,
Thank you for contacting Intel Community Forum.
I am Wani who will continue support to your case. Please allow me some time to review your issue, I will reply you back shortly.
Thanks!
Wani
Hi DanielGP,
I am sorry for keep you waiting for long time.
> IP-TRIETHERNET is a stand alone license. It is not associate to any dev kit. In other word, you can use to any supported devices as mention in IP-TRIETHERNET user guide.
> Can you explain further, how do you plan to use the license?
> Are you plan to use fix or floating license?
> Do you plan to use server for this application?
Thanks!
Wani
Hi, Wani.
Thank you for you reply. So, my answers are underlined:
>> Perfect, this is what I needed to know. Thank you!
>> Our idea is to use the license for different projects and boards. On one particular project, imagine we have 2 ethernet interfaces, which means that we would need to instantiate the IP-TRIETHERNET twice in the design. With a single standalone license, can we instantiate the IP-TRIETHERNET twice in order to work in both ethernet interfaces?
Thank you again for all your support.
Daniel Pestana.
