I got the IBIS model for Cyclone10 GX FPGA from the below site;
IBIS Models for Intel Field Programmable Gate Array Devices | Intel
But with this, I'm not able to able to identify the PIN no.s for a specific signal.
Eg; I need to simulate signals going to Pin no: M20 & M19, Y20 & Y19 and AA22 & AA21. But in the model, I'm not able to select these pins as the pin numbering is different there (Attached file for reference).
Please help me to identify the correct pin numbers in the model or do you have a separate IBIS model for these sections.
Vishnupriya
Hello Vishnupriya,
Thank you for reaching out Intel FPGA Community.
Can you share the steps you taken up until you found those pin numbering as in the attached picture?
It helps us to understand more for the issue.
Aqid
I can suggest you use Visual IBIS Editor from this link: http://www.pldworld.com/html/ftp/-mentor-/hyperlynx/visibis.htm
Is it possible for you to change to that? As I have tried to open the ibis file using the software and it seems there are the listed of pin number and its equivalent signal name. Maybe it can help you to identify which pins are been refer to by the pin number?
Aqid
