6370 Discussions
Intel ARM DS with SoCEDS on Windows 10, debugger issue
kaushal
I have issue with "Arm DS Intel Edition Toolkit" , i am running my ARM DS2020 debugger on windowd 10 (64 bit machine)
Earlier i am using ARM DS-5 along with Quartus16.1 and i am running ARRADIO
( see the web link) application without any issue on Cyclone V SoC Kit,
I have connect AD9361 board to by SoC Kit through HSMC
"https://github.com/analogdevicesinc/no-OS/tree/master/ad9361/sw
https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/baremetal
Project i have download from GitHub: (Master)
now recently i have purchase Arm DS Intel Edition Toolkit (2020), and also quartus 20.1 but nothing is working here, some how i am able to compile RTL Project on quartus, but every time i run my ARRADIO Software on ARM DS2020 it generate below error.
I have compile the project on Quartus16.1 & Quartus 18.1 also but no gain.
Error is :
Stopping running target Intel SoC FPGA - Cyclone V SoC (Dual Core) on connection
Connected to running target Intel SoC FPGA - Cyclone V SoC (Dual Core)
Execution stopped in SVC mode at S:0x00000964
S:0x00000964 TST r1,#1
cd "D:\Q16.1User\2016_R2\Software\ad9361_demo_application\ad9361"
Working directory "D:\Q16.1User\2016_R2\Software\ad9361_demo_application\ad9361"
source /v "C:\Program Files\Arm\Development Studio 2020.0\sw\debugger\configdb\Scripts\altera_target_check.py"
+print &$Peripherals::$rstmgr::$rstmgr_brgmodrst
$1 = (unsigned int*) P:0xFFD0501C
Cannot access FPGA to check SYS ID registers, expected values are:
Expected value of Peripherals::altera_avalon_sysid_c5soc_sys_id_control_slave::altera_avalon_sysid_c5soc_sys_id_control_slave_ID:
0xacd51302/0xffffffff
Expected value of Peripherals::altera_avalon_sysid_c5soc_sys_id_control_slave::altera_avalon_sysid_c5soc_sys_id_control_slave_TIMESTAMP:
0x5f7e9174/0xffffffff
file "D:\Q16.1User\2016_R2\Software\ad9361_demo_application\ad9361\u-boot-spl"
set debug-from main
start
Starting target with image D:\Q16.1User\2016_R2\Software\ad9361_demo_application\ad9361\u-boot-spl
Running from entry point
WARNING(CMD399-COR168):
! Failed to start the target
! No function named "main" could be found
WARNING(CMD407): Trying the entry point instead
wait
Execution stopped in SVC mode at S:0xFFFF0000
In start.S
S:0xFFFF0000 39,0 _start: b reset
source /v "D:\Q16.1User\2016_R2\Software\ad9361_demo_application\ad9361\debug-hosted.ds"
+reset system
ERROR(CMD463):
# in D:\Q16.1User\2016_R2\Software\ad9361_demo_application\ad9361\debug-hosted.ds:8 while executing: reset system
! The reset capability system is not available
ERROR(CMD656): The script D:\Q16.1User\2016_R2\Software\ad9361_demo_application\ad9361\debug-hosted.ds failed to complete due to an error during execution of the script
Any help/suggestion  in this regard is highly appreciate .
kaushal
EBERLAZARE_I_Intel
Are you using the same DDR size as the Project's that you are working with?
You may also want to check previous discussion on the error that you are facing with in ARM forums below:
https://community.arm.com/developer/tools-software/tools/f/armds-forum/3566/facing-issues-while-using-debugger-armaemv8-a_mp_0-on-ds5-how-to-solve-it
https://community.arm.com/developer/tools-software/tools/f/armds-forum/1151/setting-an-entry-point
