Intel Agilex F-Series development board kit is using QSPI on Active serial (AS x4) method, it is also used to bring up the FPGA device with configuration & HPS initialization.
Is that possible to use only one eMMC/SD card (using AS scheme) to bring up the FPGA device & HPS including config, initialization etc?? or else should I prefer to use the QSPI (AS x4) for configuration & SD/eMMC card for HPS initialization??
In simple words, One big memory(eMMC/SD) is fine?? or else I should use QSPI(for configuration) and eMMC/SD(for HPS data)??
I think below design is what you are looking for:
https://rocketboards.org/foswiki/Projects/AgilexSoCWithEMMCStorageOnHPS
Topic Options
