6418 Discussions
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_region_tight
dhia91
Hello all,
i describe you my problem :
i work on Cyclone V GX (SoC) and fit on quartus prime 17.1  --> i have a qsys core connected to a nios embedded core which worked up to now.
I only add on my qsys core ,  2 Avalon master bridge (32-bit address) --> connected to different IPs ( logic part)
It crashed and got internal error as following:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/vpr_common/cluster_region_tighten.c, Line: 649
[05:22:45] : [Step 3/6] Internal Error
impossible to know why ???
FYI, i test on quartus 18.1 it works...
due to project problematics we can not chang quartus version.
Can anyone help me for that ?
 thanks in avdance,
Dhia.
SyafieqS
Hi Dhia,
Can you running the compilation with ini "cl_region_tighten_v2_enable=off"?
This should avoid the IE.
dhia91
Thank you for your reply (unfortunately too late) I bypassed the problem in usign multi seed compilation and timing correction.
hwat do you mean by "  ini "cl_region_tighten_v2_enable=off"?" ==> add tcl constraint with "cl_region_tighten_v2_enable=off"
FYI, i use script compilation...
SyafieqS
Dhia,
Noted and glad you manage to solve it.
INI file is quartus setting where you can control the quartus unlike in GUI. You You can view and change user options in the .ini file with the Tcl commands set_user_option and get_user_option in the project Tcl package. The cl_region_tighten_v2_enable=off is is to disable cluster region during compilation.
dhia91
Hello all,
I re-open this post, because i stil have place and route problem with this error :
i tried to add tcl constraint : set_user_option -name CL_REGION_TIGHTEN_V2_ENABLE OFF
but quartus do not recognize it. i have this error :
ERROR: Illegal user option name: CL_REGION_TIGHTEN_V2_ENABLE. Specify a legal user option name. To get a list of legal names, use the "get_all_user_option_names" command
FYI, i use quartus 17.1
Thanks in advance.
