6031 Discussions
Is Signal probe option not available within Quartus 19.3 pro? I used it in the past as explained by an Altera Engineer, but can't find it anymore. https://www.youtube.com/watch?v=20WwtqaA1dY
AEsqu
RichardTanSY_Intel
Hi, you can refer to the document below on the guidelines in using the signal probe:
Intel® Quartus® Prime Pro Edition User Guide: Debug Tools
Let me know if it helps.
AEsqu
Thanks Richard.
So the GUI has been removed and I will have to edit the qsf or tcl.
Any reason why the GUI was removed?
AEsqu
Richard,
I followed the doc and this seems to be not supported anymore (CONNECT_SIGNAL_PROBE_PIN is not in the list anymore):
In .qsf:
set_global_assignment -name CREATE_SIGNALPROBE_PIN kaya_r_io_D1
in quartus .tcl:
set_instance_assignment -name CONNECT_SIGNAL_PROBE_PIN kaya_r_io_D1 -to rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[3].A_flexcomm|A_flexcomm|A_minuart_gen.A_minuart_core|div_inst|clk_div_inst|z_mux_inst|z
ERROR: Illegal assignment name: CONNECT_SIGNAL_PROBE_PIN. Specify a legal assignment name. To view the list of legal assignment names, run "get_all_assignment_names".
BDF_FILE
VECTOR_TEXT_FILE
TEXT_FILE
VHDL_FILE
GDF_FILE
AHDL_FILE
INCLUDE_FILE
VERILOG_FILE
SYSTEMVERILOG_FILE
VERILOG_INCLUDE_FILE
VQM_FILE
EDIF_FILE
C_FILE
CPP_FILE
CPP_INCLUDE_FILE
CUSP_FILE
DSPBUILDER_FILE
ASM_FILE
HEX_FILE
VCD_FILE
MIF_FILE
VECTOR_WAVEFORM_FILE
ZIP_VECTOR_WAVEFORM_FILE
BSF_FILE
SYM_FILE
VECTOR_TABLE_OUTPUT_FILE
LMF_FILE
TCL_SCRIPT_FILE
QUARTUS_STANDARD_DELAY_FILE
QUARTUS_SBD_FILE
QUARTUS_PTF_FILE
CDF_FILE
AEsqu
Ok the doc needs some update, this below was accepted:
set_instance_assignment -to kaya_r_io_D1 -name SIGNALPROBE_SOURCE rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[3].A_flexcomm|A_flexcomm|A_minuart_gen.A_minuart_core|div_inst|clk_div_inst|z_mux_inst|z
All signalprobe accepted keywords from the list:
SIGNALPROBE_ALLOW_OVERUSE
SIGNALPROBE_CLOCK
SIGNALPROBE_NUM_REGISTERS
SIGNALPROBE_SOURCE
SIGNALPROBE_ENABLE
SIGNALPROBE_DURING_NORMAL_COMPILATION
AEsqu
Great, quartus crashes during rapid recompile ...
last messages before the crash:
Info(20273): Intermediate fitter snapshots will be committed because Early Place is being enabled during compilation.
Info(20274): Successfully committed planned database.
Info(12517): Periphery placement operations ending: elapsed time is 00:02:49
Warning(15705): Ignored locations or region assignments to the following nodes
Warning(15706): Node "clk_a10_0" is assigned to location or region, but does not exist in design
Warning(15706): Node "clk_a10_1" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C10" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C13" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C14" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C15" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C16" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C17" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C18" is assigned to location or region, but does not exist in design
Warning(15706): Node "kaya_r_io_C9" is assigned to location or region, but does not exist in design
Info(11165): Fitter preparation operations ending: elapsed time is 00:02:04
Problem Details
Error:
Internal Error: Sub-system: VPR20KMAIN, File: /quartus/fitter/vpr20k/bsyn_interface/bi_bsyn.cpp, Line: 480
enabled
Stack Trace:
  0x44951d: BSYN_CONFIG::BSYN_CONFIG(BSYN_FLOW_TYPE) [clone .cold.1340] + 0x75 (fitter_vpr20kmain)
  0x7ab232: BSYN_CONFIG::Init(BSYN_FLOW_TYPE) + 0x62 (fitter_vpr20kmain)
  0x7b403: FDRGN_EXPERT::run_vpr(bool, bool, bool, bool, BSYN_FLOW_TYPE) + 0x163 (fitter_fdrgn)
  0x882fb: FDRGN_EXPERT::early_place() + 0x7b (fitter_fdrgn)
  0x2a44f: fit2_fit_early_place_auto + 0xe9 (comp_fit2)
  0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
  0x13d7f: fit2_fit_early_place + 0x2b9 (comp_fit2)
  0x4de7b: TclEvalEx + 0x68b (tcl8.6)
  0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6)
  0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6)
  0x14916: qexe_evaluate_tcl_script(std::string const&) + 0x44c (comp_qexe)
  0x19a1c: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x417 (comp_qexe)
  0x1a9d5: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x558 (comp_qexe)
  0x3922e: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::string const&, std::string const&, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xed (comp_qcu)
  0x41d1c: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x259 (comp_qcu)
  0x1d69e: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x6a0 (comp_qexe)
  0x4032f2: qfit2_main(int, char const**) + 0x92 (quartus_fit)
  0x3ef00: msg_main_thread(void*) + 0x10 (ccl_msg)
  0x41114: msg_thread_wrapper(void* (*)(void*), void*) + 0x6e (ccl_msg)
  0x11f0c: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem)
   0xc728: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
   0x6d85: thr_thread_wrapper + 0x15 (ccl_thr)
  0x41c90: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x148 (ccl_msg)
  0x1ed5d: __libc_start_main + 0xfd (c)
  0x402ae5: (quartus_fit)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Red Hat
OS version: 6
Quartus Prime Information
Address bits: 64
Version: 19.3.0
Build: 222
Edition: Pro Edition
I will try with a full compilation and the command in the qsf:
set_instance_assignment -name SIGNALPROBE_SOURCE rfd_ic_i|u_top|u_core|u_atlas|A_flexcomm_array[3].A_flexcomm|A_flexcomm|A_minuart_gen.A_minuart_core|div_inst|clk_div_inst|z_mux_inst|z -to kaya_r_io_D1
RichardTanSY_Intel
Hi, you can use the example below to test the Signal probe flow. You can then modify the example to debug your current projects.
Example of Using Signal Probe Routing Feature
RichardTanSY_Intel
I do not know the exact reason why the GUI was removed. If GUI is more convenience, I can send a request to the engineering team to add this feature in the future Quartus version.
AEsqu
That's ok, I will edit the qsf file directly now, using the node finder gui to find the points to probe out.
RichardTanSY_Intel
Hi, do you need further help with the signal probe?
AEsqu
Hi Richard,
no, but I would like Intel to update the documentation, it is outdated and incorrect, as I mentioned before.
Have a great Holiday ;-)
RichardTanSY_Intel
Thanks for the constructive feedback. We will review and update the document.
Happy holiday to you too. :)
