Is it possible to turn off auto find file in quartus 19.3?
Quartus auto finds a VHDL file and pick the wrong version of it,
while I specify the file I want in the qsf (ignored for some reason):
set_global_assignment -name VHDL_FILE ../../RTL/GF_C040RF_7M5S2U_NXP_IO_MFIO2V5FS_arria10.vhd -library work
When I delete the file it auto find (../../RTL/GF_C040RF_7M5S2U_NXP_IO_MFIO2V5FS.vhd)
then quartus goes further.
Note: GF_C040RF_7M5S2U_NXP_IO_MFIO2V5FS.vhd contains the stratix III IO pad and it is not compatible with the arria 10 ()dataio for stratix III, padio for arria X).
Well I globally removed the search path to solve this:
#set_global_assignment -name SEARCH_PATH ../../INTERFACE
#set_global_assignment -name SEARCH_PATH ../../RTL
But it would be good that quartus does not try to compile a module that has the same name than the provided file
using the auto found RTL file.
Thanks for the feedback. We will look into this so that the future Quartus will give a better customer experience.
