We are having a dispute here whether we must drive the nCONFIG pin with a open drain gate (together with a pull-up to VCCIO) or if we can use a push-pull driver (without any pull). Some of us thinks the documentation in some places can be interpreted as if the nCONFIG pin also can be an output while I personally beleive it will always be an input, during both configuration and in user mode.
Hi Gunnar,
Yes, nCONFIG pin is input only during user mode.
Upon power-up, the nCONFIG pin must be pulled high. Connect this pin directly or through a 10-kΩ resistor to VCCIO.
check section 2.3.2 from below link also refer pin connection guidelines.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf
Anand
Is the nCONFIG pin always an input or can it ever be an output?
>> During user mode, the nCONFIG pin is Input only. Can not be output under user mode.
Is the nCONFIG pin ok to drive with a regular totem-pole output gate?
>> What exactly you trying to do??
