Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Issue with transmitting data using cyclone 3 development board
Hi All,
I am using a cyclone 3 development board , where i have my own Ethernet MAC in the design.
I have programmed the corresponding Marvell PHY Registers and i am able to receive the
packets. But I am unable to transmit any packets. I am trying to use the Packet generator
available in the Marvel Phy to see if the Phy is capable of transmitting. BUT i do not see any
transmit activity. Below is the sequence followed to program PHY registers to enable transmit activity. Please
let me know what could be the issue. I made sure that there are no timing issues related to the TX_CLK.
I do not see any activity on the LED_TX which i set to blink on rx/tx activity.
Register = 0; Value = 0x140; //Control Register Register = 0; Value = 0x8140; //Control Register
Register = 20; Value = 0xce3; //Extended PHY specific control Register
Register = 0; Value = 0x1140; //Control Register
Register = 0; Value = 0x9140; //Control Register
Register = 16; Value = 0x78; // MDIO CROSS OVER + DISABLE 125CLK
Register = 4; Value = 0x1e1; //Auto negotiation Advertisement
Register = 9; Value = 0x1200; //1000BASET-Control Register
Register = 18; Value = 0xffff; //Interrupt Enable Register
Register = 24; Value = 0x1041; //LED CONTROL REGISTER
Register = 0x6c; Value = 0x848b; //Extended Phy Specific Status Register
Register = 0x0; Value = 0x9140; //Control Register
Register = 29; Value = 0x12; //Extended Register
Register = 30; Value = 0x20; // Packet Generator enable Reg 30 page 18
Please let me know what could be going wrong with the transmit activity.
Deepali
