hello all,
I am having a strange peoblem. I configured everything so that there will be a PCIe link between the FPGA and a switch. When I use *.sof everything works perfect, when I use *.JIC with EPCS128 there is no conection. I checked the following: 1. voltages in Power up by recounfiguring after all the power Stabilized. no change 2. reseting the switch a minute after the FPGA was configured. no change 3. configuring PCI transmition. it works. So it is not voltages, nor the switch ( it works with sof), not timing from configure of FPGA PCIe and switch and the EPCS works fine coz it configures something else. Plz do help, thanks.Link Copied
Topic Options
