Community
cancel
Showing results for
Search instead for
Did you mean:
TGao
JTAG can't connect sometime
Dear Sir/Madam,
Jtag cant't connect sometime , and error hint below:
微信图片_20200608171119.png​Ted.Gao
YuanLi_S_Intel
Hi Ted,
There are few possibility that causes this error, can you check the following?
[1] Can you check if you are selecting the correct configuration scheme, device OPN in Quartus design?
[2] Can you change TCK frequency to 6MHz?
Thank You.
Bruce.
TGao
Hi SooY, 1. The OPN is correct 2. I use usb blaster ,can’t change the frequency. Ted
YuanLi_S_Intel
Hi Ted,
Can you please elaborate further so that i can get a full picture on this scenario?
May i know what configuration scheme you are using? Have you tried to program with a SOF file? When you mention about sometimes JTAG cant connect. What does this mean? Please elaborate.
Thank YOu
TGao
Hi SooY Solved, Thanks. Ted.Gao
YuanLi_S_Intel
Hi Ted,
Oh, i am glad it helps. May i know what did you do to make it work? Perhaps we can help the community in this forum as well.
Thank You.
Bruce
TGao
Hi SooY, The welding of the plate is not very good. After re welding, the problem is solved. Ted.Gao
YuanLi_S_Intel
Hi Ted,
Thanks for your sharing. Hopefully it helps the community here. I am closing this thread. Please rate me good if my support is good.
Thank You.
