Dear Sir/Madam,
Jtag cant't connect sometime , and error hint below:
Ted.Gao
Hi Ted,
There are few possibility that causes this error, can you check the following?
[1] Can you check if you are selecting the correct configuration scheme, device OPN in Quartus design?
[2] Can you change TCK frequency to 6MHz?
Thank You.
Bruce.
Hi Ted,
Can you please elaborate further so that i can get a full picture on this scenario?
May i know what configuration scheme you are using? Have you tried to program with a SOF file? When you mention about sometimes JTAG cant connect. What does this mean? Please elaborate.
Thank YOu
Hi Ted,
Oh, i am glad it helps. May i know what did you do to make it work? Perhaps we can help the community in this forum as well.
Thank You.
Bruce
Hi Ted,
Thanks for your sharing. Hopefully it helps the community here. I am closing this thread. Please rate me good if my support is good.
Thank You.
