I'm trying to program my DE0-CV board using Quartus 16.1 on Ubuntu and I'm having a lot of trouble getting the usbblaster jtag programming to work.
When I try to program the board with the vga demo files provided by Altera, the programmer hangs and eventually times out reporting that it "Can't access JTAG Chain". I also ran the JTAG Debugger and it reports that it "Can't initialize Chain - Error locking chain or hardware is not set." It's very strange because my computer detects the hardware just fine and the little green status LED even lights up when I begin programming. It just never completes successfully. Just FYI, I've made sure that non-root users have access to the usbblaster by adding the necessary udev rules. I know the issue is nothing related to hardware because I can program the board perfectly fine if I use Windows. Thanks for the help!- Tags:
- jtag
- usb blaster
Did you ever figure this out?
I'm having the same issue and would really appreciate the help.
