ITEM NUMBER
FFV1J-ICS-0718-00
FFV1J-ICS-0958-00
FFV1J-ICS-0972-00
FFV1J-ICS-0984-00
FFV1J-ICS-0989-00
FFV1J-ICS-0999-00
DESCRIPTION
IC,GB ETHER CONT,9X9MM,QFN64
IC 8 SPEED,27X27MM,FBGA672
IC, UF50, ALTERA, FBGA2397
IC, E+H-TILE, F50, FBGA2397
IC,PLAT CONTROL,FCBGA1310
IC, CONTROLLER,FCBGA1310
MPN
WGI210AT SLJXQ (MM#925131)
10M40DCF672C8G
1ST280EU2F50E2VG
1ST165EU2F50E2VG
EY82C627 SR3HG (MM#957627)
EY82C627 QS6B, 999DL8
DESCRIPTION MATCHES WITH MPN (YES/NO)
PLEASE PROVIDE CORRECT ORDERABLE PART NUMBER
STATUS (ACTIVE OR OBSOLETE OR NRND)
IF NRND, PLEASE PROVIDE LTB AND LTS DATE
IF OBSOLETE SUGGEST EXACT DROP-IN REPLACEMENT
PACKING TYPE (TAPE & REEL, ROLL,TRAY,TUBE AND BULK)
MPN IS AVAILABLE IN TAPE&REEL (YES/NO)
PROVIDE CORRECT ORDERABLE MPN FOR TAPE&REEL
MSL (MOITURE SESNSITIVITY LEVEL)
SMT (YES/NO) (SURFACE MOUNT/THROUGH HOLE TECH)
PACKAGE TYPE/CASE SIZE
ROHS COMPLAINTS (YES/NO)
PART MARKING
SHELF LIFE (IN DAYS)
DATA SHEET-LINK / PDF FILE
Thank you for contacting Intel Community.
Please give me sometime to check and gain all of the information. Thank you.
Aim
Apologize for the delay in response as we just received the required info for the queries.
Please be noted to post a separate forum case for different product as it will be answered by different team. Below is the answer for only FPGA product, for other product, please make a new post in the forum with the correct product families.:
10M40DCF672C8G-Active
1ST280EU2F50E2VG-Active
1ST165EU2F50E2VG-Active
10M40DCF672C8G- Tray
1ST280EU2F50E2VG- Tray
1ST165EU2F50E2VG- Tray
Please contact our distributor for more details
Kindly go to the link below for MSL:
https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/msl.html
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an353.pdf
10M40DCF672C8G- FBGA
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_overview.pdf (Page 5)
Please be noted that Intel FPGA is compliant with RoHS (EU) 2015/863. You can find the related information from the following link:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2019/does-intel-fpga-compliance-with-restrictions-of-hazardous-substa.html
PART MARKING
send in private message
Please note that Intel devices has the shelf life of 36months (per JEDEC J-STD-033B.1). Please refer to the ADV document below.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/pcn/adv1818.pdf
10M40DCF672C8G- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
Stratix 10- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/s10_datasheet.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/s10_tx_overview.pdf
This the only info that can be provided here. Thank you.
Aim
