Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
5198 Discussions
LCD DE2-115 Initialization poblem
Hello everyone!! I'm trying to initialize LCD in the DE2-115 board. I know that the LCD is based in HDD44780U and I have following the datasheet to initialize it but the LCD turns crazy.
See my Initiazitaion code:
LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY lcd IS PORT( clock_50 : IN STD_LOGIC; reset_n : IN STD_LOGIC; lcd_enable : IN STD_LOGIC; lcd_bus : IN STD_LOGIC_VECTOR(9 DOWNTO 0); -- DATOS Y CONTROL busy : OUT STD_LOGIC := '1'; -- LIBRE/OCUPADO lcd_rw, lcd_rs, lcd_en : OUT STD_LOGIC; --read/write, setup/data y ENABLE lcd_on: out std_logic:='1'; -- lcd_blon: out std_logic:='1'; lcd_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); -- DATOS HACIA LCD END lcd; ARCHITECTURE controller OF lcd IS TYPE CONTROL IS(power_up, initialize, ready, send); SIGNAL state : CONTROL; CONSTANT freq : INTEGER := 50; -- 50 Mhz BEGIN PROCESS(clock_50) VARIABLE clk_count : INTEGER := 0; --Contador de timming BEGIN IF(clock_50'EVENT and clock_50 = '1') THEN CASE state IS -- Espera de 50 ms para inicilización de Vcc WHEN power_up => busy <= '1'; IF(clk_count < (50000 * freq)) THEN --espera de 50 ms clk_count := clk_count + 1; state <= power_up; ELSE --power-up completado clk_count := 0; lcd_rs <= '0'; lcd_rw <= '0'; lcd_data <= "00110000"; state <= initialize; END IF; -- Inicialización de LCD WHEN initialize => busy <= '1'; clk_count := clk_count + 1; IF(clk_count < (40 * freq)) THEN -- espera de 10us lcd_data <= "00111100"; --2-line mode, display on --lcd_data <= "00110100"; --1-line mode, display on --lcd_data <= "00110000"; --1-line mdoe, display off --lcd_data <= "00111000"; --2-line mode, display off lcd_en <= '1'; state <= initialize; -- ELSIF(clk_count < (50 * freq)) THEN --espera de 50 us -- lcd_data <= "00000000"; -- lcd_en <= '0'; -- state <= initialize; ELSIF(clk_count < (80 * freq)) and (clk_count > (40 * freq)) THEN --display on/off control -- lcd_data <= "00001100"; --display on, cursor off, parpadeo off -- lcd_data <= "00001101"; --display on, cursor off, parpadeo on -- lcd_data <= "00001110"; --display on, cursor on, parpadeo off lcd_data <= "00001111"; --display on, cursor on, parpadeo on --lcd_data <= "00001000"; --display off, cursor off, parpadeo off --lcd_data <= "00001001"; --display off, cursor off, parpadeo on --lcd_data <= "00001010"; --display off, cursor on, parpadeo off --lcd_data <= "00001011"; --display off, cursor on, parpadeo on lcd_en <= '1'; state <= initialize; -- ELSIF(clk_count < (120 * freq)) THEN --espera 50 us -- lcd_data <= "00000000"; -- lcd_en <= '0'; -- state <= initialize; ELSIF (clk_count > (80 * freq)) and (clk_count < (1610 * freq)) THEN -- limpiado de pantalla lcd_data <= "00000001"; lcd_en <= '1'; state <= initialize; -- ELSIF(clk_count < (1620 * freq)) THEN --espera 2 ms -- lcd_data <= "00000000"; -- lcd_en <= '0'; -- state <= initialize; ELSIF(clk_count < (1650 * freq)) and (clk_count > (1610 * freq)) THEN --entry mode set // espera 10 us lcd_data <= "00000110"; --increment mode, entire shift off --lcd_data <= "00000111"; --increment mode, entire shift on --lcd_data <= "00000100"; --decrement mode, entire shift off --lcd_data <= "00000101"; --decrement mode, entire shift on lcd_en <= '1'; state <= initialize; ELSIF(clk_count < (2200 * freq)) THEN --wait 60 us lcd_data <= "00000000"; lcd_en <= '0'; state <= initialize; ELSE --inicialización completada clk_count := 0; busy <= '0'; state <= ready; END IF; -- Espera al enable para el correcto envio de datos WHEN ready => IF(lcd_enable = '1') THEN busy <= '1'; lcd_rs <= lcd_bus(9); lcd_rw <= lcd_bus(8); lcd_data <= lcd_bus(7 DOWNTO 0); clk_count := 0; state <= send; ELSE busy <= '0'; lcd_rs <= '0'; lcd_rw <= '0'; lcd_data <= "00000000"; clk_count := 0; state <= ready; END IF; --send instruction to lcd WHEN send => busy <= '1'; IF(clk_count < (35 * freq)) THEN --do not exit for 50us busy <= '1'; IF(clk_count < 3*freq) THEN --negative enable lcd_en <= '0'; ELSIF(clk_count < (8 * freq)) THEN --positive enable half-cycle lcd_en <= '1'; ELSIF(clk_count < (34* freq)) THEN --negative enable half-cycle lcd_en <= '0'; END IF; clk_count := clk_count + 1; state <= send; ELSE clk_count := 0; state <= ready; END IF; END CASE; --reset IF(reset_n = '0') THEN state <= power_up; END IF; END IF; END PROCESS; END controller;
And see my example to print in the lcd:
LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY lcd_example IS PORT( clock_50 : IN STD_LOGIC; lcd_rw, lcd_rs, lcd_en : OUT STD_LOGIC; lcd_on: out std_logic:='1'; -- lcd_blon: out std_logic:='1'; lcd_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0) &nbsp;); END lcd_example; ARCHITECTURE behavior OF lcd_example IS SIGNAL lcd_enable : STD_LOGIC; SIGNAL lcd_bus : STD_LOGIC_VECTOR(9 DOWNTO 0); SIGNAL lcd_busy : STD_LOGIC; COMPONENT lcd IS PORT( clock_50 : IN STD_LOGIC; reset_n : IN STD_LOGIC; lcd_enable : IN STD_LOGIC; lcd_bus : IN STD_LOGIC_VECTOR(9 DOWNTO 0); busy : OUT STD_LOGIC; lcd_rw, lcd_rs, lcd_en : OUT STD_LOGIC; lcd_on: out std_logic:='1'; lcd_blon: out std_logic:='1'; lcd_data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); END COMPONENT; BEGIN --Instanciación dut: lcd PORT MAP(clock_50=> clock_50, reset_n => '1', lcd_enable => lcd_enable, lcd_bus => lcd_bus, busy => lcd_busy, lcd_rw => lcd_rw, lcd_rs => lcd_rs, lcd_en => lcd_en, lcd_on=>lcd_on, lcd_data => lcd_data); PROCESS(clock_50) VARIABLE char : INTEGER RANGE 0 TO 10 := 0; BEGIN IF(clock_50'EVENT AND clock_50 = '1') THEN IF(lcd_busy = '0' AND lcd_enable = '0') THEN lcd_enable <= '1'; IF(char < 10) THEN char := char + 1; END IF; CASE char IS WHEN 1 => lcd_bus <= "1000110001"; WHEN 2 => lcd_bus <= "1000110010"; WHEN 3 => lcd_bus <= "1000110011"; WHEN 4 => lcd_bus <= "1000110100"; WHEN 5 => lcd_bus <= "1000110101"; WHEN 6 => lcd_bus <= "1000110110"; WHEN 7 => lcd_bus <= "1000110111"; WHEN 8 => lcd_bus <= "1000111000"; WHEN 9 => lcd_bus <= "1000111001"; WHEN OTHERS => lcd_enable <= '0'; END CASE; ELSE lcd_enable <= '0'; END IF; END IF; END PROCESS; END behavior;
is there anyone could help me?
Thank you very much.
