After successfully having set up Linux on the MAX10 Dev Kit (using the tutorial from rocketboards for rev. C kit) and factory restoring (using the design examples included with the kit), the board name, board P/N, serial number and board version appear to have been corrupted (looking at the Board Test System, see screenshot) - or is this something I should expect? Thanks.
https://alteraforum.com/forum/attachment.php?attachmentid=15856&stc=1Link Copied
This may happen due to the character encoding on the Linux platform. If the rest of the board works as it should, my guess is that there are no other issues. You can leave this as is.
I would appreciate if you elaborated. Is it possible to change these values voluntarily - if so, is there a document with the required steps? (are they stored in QSPI Flash? I would've thought not.).
I used Intel design tools under Windows 10, prior to and after factory restoring - to avoid confusion. Linux was only written to QSPI.
I cannot leave it as is, because as far as I can deduce from this context, the values must've been read from mutable memory. This would imply I cannot validate the board, except by reading the inscriptions on the PCB or the packaging and hence, I have little guarantee that my product is authentic.
I've dissected the Board Test System DDR3 design and indeed, the board information is actually hard coded in the product_info IP. My initial reasoning towards board validation was not sensible.
