6407 Discussions
MAX10 FPGA Develop kit replacement (repair) request
wuhannus
We purchased three sets of MAX10 FPGA develop kit (Part number: DK-DEV-10M50-A) in July 2020 through Mouser.sg.
All these three sets function well when we started deploy our project using the HSMC connector. However, recently , two of them are malfunction in the HSMC connector. Therefore, we want to initiate the service support to replace(or repair) these two malfunction sets. Regarding these two malfunction sets, the SOF files are still able to upload successfuly. Only the HSMC connector cannout output normally as in previous usage.
The devices are operated in lab environment with no physical damage.
Kindly thanks for your reply regarding the solutions.
Attachment is one set with HSMC connector malfunction for your information.
AR_A_Intel
Hi Sir
Welcome to INTEL forum. Could you help provide the following for warranty checking before RMA process?
Name:
Email Address:
Company/University Name:
Dev kit OPN :
Serial Number :
A copy of invoice that shows time and date of purchase. You can also reply/attach your file in private message.
wuhannus
Thanks for the reply. Could you help me
Email Address: elewuh@nus.edu.sg
Company/University Name: National University of Singapore
1st set
Dev kit OPN : 16090009-1987
Serial Number : 10M50DA0005098
 2nd set
Dev kit OPN : 16090009-1151
Serial Number : 10M50DA0005096
A copy of invoice is shown in the attachment. The FPGA sets are highlighted in item 31.
AR_A_Intel
Hello
Please give me some time to further check with our Customer service team regarding your issue. I’ll be back with an update.
AR_A_Intel
Hi Sir
Thanks for your patience. Done checking with customer service team, your device is still in warranty. We will proceed with RMA proses. Before proceeding with dev kit RMA, Intel requires details information for RMA (Failure Analysis) request. The failure description you provided is too general to understand the actual failure behavior at your site. Intel requires details information. Please help to answer questions below in order for us to better understand your position.
1. What is the failure symptom? Please elaborate the failure symptom in detail.
2. When did the failure happen? How you discover the failure?
3. How did you determine the failure? Please elaborate the procedures.
4. Does the failure unit ever working before failure?
5. Did you swap the failure board with a known good board?
wuhannus
Thanks for the help.
The following is detail answer.
The failure symptom is when the FPGA board is turned-on, there is light short-current sound.
The failure FPGA board is still able to upload the SOF files.
During the measurement, we use micro probes contact with the HSMC pins directly to read data from the pins. At intial measurement, it works well. After several times measurement, it doesn't give any data signal out. The measurement pin will stay high or low for all the time. Then, after turn-on and off again, we hear the short-current sound.
The failure is determined by the successul measurement of previous several times. And compared with our third FPGA which is still working good with no short-current sound.
Yes, the failure units ever working before failure.
Yes, we repeat the same measurements between failure boards with the known good board.
 Please feel free to let us know if you have any more questions.
AR_A_Intel
Hello
Thanks for your update. Please give me some time to check and open RMA request ticket.
AR_A_Intel
Hello Sir
Thanks for your patience. We have open a ticket regarding you issue. Contact local authorized Intel Distributors near you (Mouser.sg). to request RMA together with the following information. Distributor link https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
a) Development Kit S/N :
             1st set
2nd set
b) IPS No. 00547130
c) The debugging steps done:
During the measurement, we use micro probes contact with the HSMC pins directly to read data from the pins. At initial measurement, it works well. After several times measurement, it doesn't give any data signal out. The measurement pin will stay high or low for all the time. Then, after turn-on and off again, we hear the short-current sound.
Please notify your distributor that the dev.kit is in working condition before problem.
wuhannus
Hi Mr. AabdRahman,
Thanks very much for the help.
I will follow your suggestion to contact the vendor Mouser.
Have a good day.
AR_A_Intel
Sounds good, hope everything is working well at your side. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
