I downloaded max10_RSU.par from Design Store "MAX10 Remote System Upgrade (RSU) over UART for Nios II Processor".
In the file you downloaded, there is a remote_update.c file.
Can I just copy and use it on the following devices?
10M08SAE144C8G
10M16SAE144C8G
If you can't, please tell me how to fix it.
If you set max10_RSU.par to
10M08SAE144C8G
10M16SAE144C8G
Can I just change the address of the device, pins, and memory to use it?
Please let me know.
Yes, you can, but you must adjust the device address and make sure that all settings are compatible with the new device. You can simply re-create the design for the required device and include the .c files you need to the project (after editing it).
Thank you for your reply.
