6355 Discussions
MAX10 development kit uart issue "non genuine device"
GZhan28
Hi Intel,
I purcahsed a MAX10 development kit from Digikey--intel order code : DK-DEV-10M50-A
I am using windows 10 system. When I try to use serial port, my tera term or putty show non genuine device.
I searched a bit and find it may related to the FTDI chip you use on board. Can you help me solve the issue?
AnilErinch_A_Intel
Hi
Can you let us know under the device manager in Windows  whether the USB serial port is being shown when the kit is being plugged in to the system. If not what is being shown after the kit is connected.
Also can you plugin the Device  to a Linux machine or a Windows 7 machine  and let us know whether the same issue persists.
This is to check  that the issue is related to FTDI driver  in the Windows 10 upgrade or not.
Thanks and Regards
Anil
GZhan28
Under device manager, the port can be correctly seen.
It works perfect under windows7 because windows7 driver does not detect fake chip. But I have limited access to win7 now, and I do not have Linux.
I need this board work with window 10.
AnilErinch_A_Intel
Please let us know the version details about the driver.
Also if you cannot get access to any machine other than Windows 10 , please  try to use an older version of driver and see that if the issue still persists.
As we cannot comment on what is the mechanism used by the driver software to judge a chip to be non genuine  , you can try to get the board working with an older version of driver.
Thanks and Regards
Anil
AnilErinch_A_Intel
Hi ,
Hope you are able to work with the board as per the suggestions related to the driver.
Thanks and Regards
Anil
