Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
MAX10 with parallel flash chip
is it possible to boot NIOS processor in MAX 10 FPGA with Parallel flash chip (adding tristate controller IP in QSYS) ?
i know EPCS or UFM memory is possible but i want to know the external flash is possible or not .please confirm?
Highlighted
Re: MAX10 with parallel flash chip
Hi, Satish
Yes MAX10 supports external parallel flash, please refer to below.
https://www.intel.com/content/www/us/en/programmable/documentation/sss1411439280066.html#sss14114500...
Eric
Highlighted
Hi, Sathish
Do you still have any questions ?
Eric
Highlighted
NO .i want to know is it possible to boot NIOS from external IO flash using srec file .? NOT EPCS and MICRON FLASH.
