6339 Discussions
MAX10 with parallel flash chip
sRama28
is it possible to boot NIOS processor in MAX 10 FPGA with Parallel flash chip (adding tristate controller IP in QSYS) ?
i know EPCS or UFM memory is possible but i want to know the external flash is possible or not .please confirm?
EricMunYew_C_Intel
Hi, Satish
Yes MAX10 supports external parallel flash, please refer to below.
https://www.intel.com/content/www/us/en/programmable/documentation/sss1411439280066.html#sss1411450059290
Eric
EricMunYew_C_Intel
Hi, Sathish
Do you still have any questions ?
Eric
sRama28
NO .i want to know is it possible to boot NIOS from external IO flash using srec file .? NOT EPCS and MICRON FLASH.
EricMunYew_C_Intel
Hi, Sathish
May I know what do you mean by IO flash ?
Eric
EricMunYew_C_Intel
Hi, Sathish
You can boot Nios II with MAX10 FPGA from an external parallel flash.
You may refer to below for the implementation:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/edh_ed_handbook.pdf (page314)
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_avalon_tc.pdf
By the way, can we close it if you have no more inquiry ?
Eric
