I need help to choose the right MCIO cables and MCIO-PCIe Gen5 adapter to connect an Agilex 7 M-series dev kit to a host over CXL (Compute Express Link). The host is a Lenovo workstation featuring 2x Intel Xeon Gold 6416H (2x18-core, 45MB Cache, up to 4.20GHz) and 4 PCIe 5.0 slots.
Is there a recommended set of MCIO cables and MCIO-PCIe adapters that have been tested and with Agilex 7 M-series dev kit?
In theory, I should be able to use this MCIO-PCIe adapter together with two MCIO SFF-TA-1016 8i cables, but could find no cross reference to supported hosts and FPGA devices.
Thank you for your help,
Denisa Constantinescu
Hi Denisa,
The Agilex 7 I-series Dev Kit (2xR-Tile+1xF-Tile) MCIO connector can work with Amphenol cable P/N: HMC74-1492 in a PCIe Gen5 test. This is the only info I have so far. Hope this helps.
Rong
Thanks for the feedback. I'll close this case.
Rong
Hi Denisa:
Have you tried this adaptor and cable you mentioned above,we looking for this adaptor too.
Regards and thanaks.
