Hey guys!
I'm try compile a c++ project, and i include libraries for openCV.
Now i need use a makefile, im try edit a makefile that came with the vector_add example.
But i have error's and i dont can compile.
You can give me help please?
# Copyright (C) 2013-2018 Altera Corporation, San Jose, California, USA. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a copy of this
# software and associated documentation files (the "Software"), to deal in the Software
# without restriction, including without limitation the rights to use, copy, modify, merge,
# publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to
# whom the Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all copies or
# substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
# EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
# OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
# NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
# HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
# OTHER DEALINGS IN THE SOFTWARE.
# This agreement shall be governed in all respects by the laws of the State of California and
# by the laws of the United States of America.
# This is a GNU Makefile.
# You must configure INTELFPGAOCLSDKROOT to point the root directory of the Intel(R) FPGA SDK for OpenCL(TM)
# software installation.
# See http://www.altera.com/literature/hb/opencl-sdk/aocl_getting_started.pdf
# for more information on installing and configuring the Intel(R) FPGA SDK for OpenCL(TM).
ifeq ($(VERBOSE),1)
ECHO :=
else
ECHO := @
endif
# Where is the Intel(R) FPGA SDK for OpenCL(TM) software?
ifeq ($(wildcard $(INTELFPGAOCLSDKROOT)),)
$(error Set INTELFPGAOCLSDKROOT to the root directory of the Intel(R) FPGA SDK for OpenCL(TM) software installation)
endif
ifeq ($(wildcard $(INTELFPGAOCLSDKROOT)/host/include/CL/opencl.h),)
$(error Set INTELFPGAOCLSDKROOT to the root directory of the Intel(R) FPGA SDK for OpenCL(TM) software installation.)
endif
# OpenCL compile and link flags.
AOCL_COMPILE_CONFIG := $(shell aocl compile-config --arm)
AOCL_LINK_CONFIG := $(shell aocl link-config --arm)
# Compilation flags
ifeq ($(DEBUG),1)
CXXFLAGS += -g
else
CXXFLAGS += -O2
endif
# Compiler. ARM cross-compiler.
CXX := arm-linux-gnueabihf-g++
OCV_INCLUDES = -I$(OPENCL4_INCLUDE)
OCV_LIBDIRS = -L$(OPENCL4_LIB)
OCV_LIBS = -lopencv_core440 -lopencv_highgui440
# Target
TARGET := host
TARGET_DIR := bin
# Directories
INC_DIRS := ../common/inc
LIB_DIRS :=
# Files
INCS := $(wildcard )
SRCS := $(wildcard host/src/*.cpp ../common/src/AOCLUtils/*.cpp)
LIBS := rt pthread
# Make it all!
all : $(TARGET_DIR)/$(TARGET)
#$(OCV_LIBS) $(OPENCL4_INCLUDE) $(OPENCL4_LIB)
# Host executable target.
$(TARGET_DIR)/$(TARGET) : Makefile $(SRCS) $(INCS) $(TARGET_DIR)
$(ECHO)$(CXX) $(CPPFLAGS) $(CXXFLAGS) -fPIC $(foreach D,$(INC_DIRS),-I$D) \
$(AOCL_COMPILE_CONFIG) $(SRCS) $(AOCL_LINK_CONFIG) \
$(foreach D,$(LIB_DIRS),-L$D) \
$(foreach L,$(LIBS),-l$L) \
-o $(TARGET_DIR)/$(TARGET)
-o
$(TARGET_DIR) :
$(ECHO)mkdir $(TARGET_DIR)
# Standard make targets
clean :
$(ECHO)rm -f $(TARGET_DIR)/$(TARGET)
.PHONY : all clean
Please check the below link
https://rocketboards.org/foswiki/Projects/OpenCVPort
and let us know whether this is helpful.
Also since this is showing undefined reference , you can check whether all the library files are included properly.
Thanks and Regards
Anil
