When using the Max V CPLD Dev Board, is there access to use the on board clocks as a resource?
There's a 10MHz (MaxV clock), 6MHz (usb) and a 24MHz xtal on the board, but I dont see these appearing anywhere in the documentation as clocks that can be used. I can always connect an external clock connection but seems odd the ones already there cant be used.Link Copied
The reference manual clarifies that the 10 MHz clock is directly driving the MAX V but doesn't list the pin number.
The information can be found however both in the schematic diagram as well as in the pin assignments of the example designs.set_location_assignment PIN_H5 -to CLK_SE_AR
