Hi all,
Can use a 200 MHZ clock with the Cyclone V GT uni-phy hard memory controller. I am hoping to get the data into the memory faster if I can run the interface at a higher rate. I will still run the core at 300 MHZ, but I want to run the ref clock at 200MHz. Does anyone know if this can be done? Thanks, Fly-GuyLink Copied
Haven't checked this out personally but i guess best way to verify 100% is just to come up with a simple design and quickly do the assignments to see if the board can handle the settings, =)
