6410 Discussions
NIOS II cannot run from an external memory QSPI?
Olee01
I've created the design based on this document but it is not working
https://www.eeweb.com/app-notes/download/169865
FawazJ_Altera
Hello.
I would check the following items:
1- Make sure Nios II reset vector and exception vector are both pointing to QSPI
2- Make sure you use 25MHZ clock as maximum to the QSPI IP.
3- Try to use PLL for your system clocking. One clock would be for the system.
Please let me know if any of the debug steps would help.
FawazJ_Altera
Hello.
Olee01
I was using external clock for the Qspi block once I used the PLL it is working now.
