I've purchased a nios license about a year and a half ago
About a month ago I've tried to transfer the license to another computer
after generating the licensee from the intel web site and uploaded the dat file I got this massage below
does anybody familiar with this problem?
Hi YYako,
Can you provide the following information?
- License.dat file
- Host ID
- Quartus version and edition (Pro /Standard)
Attached the license.dat file and host id
I'm using the 18.1 quartus version the lite edition
[cid:image002.jpg@01D4CCED.73A38A00]
Hi YYako,
There is no attachment here. Could you reattach?
Kindly provide the screenshot of License Setup as well.
I've attached the DOT file here
[cid:image001.png@01D4CDBA.7F706330]
Hi YYako,
I could not find the attached item. Are you attaching via email or web?
Via mail
Should I attaché it via web?
Hi YYako,
- The Lite edition software does not require license. You may click cancel.
- Do you see the NIOS II IP license in the license setup? Can you provide a screenshot?
- For the attachment, you may try to zip the file or copy to a .txt file
Hi YYako,
Any updates?
I've been given a temp licensee for the next 2 months
I have a big project coming up so i haven't had the chance to try and fix the problem
I will update you next week
Hi YYako,
Any updates?
Sorry, Haven’t had the time to check it yet
Get back to you tomorrow after ill check it
Thanks'
Sure
It seems to be OK
I choose cancel instead of OK and now I can compile my code and produce a SOF FILE
Thank you
Topic Options
