In Nios II C/C++ Editor, a line can be commented/Uncommented by keys Ctrl+/. But that only works for a single line of code. Is there any short-cuts or commands that works for a block of highlighted/selected codes? Thank you, OnePlusOneLink Copied
highlight/select lines then right click
HI,
The Comment/Uncomment is in the Popup Menu of Right-Click if a block of code is selected in Quartus-ii editor. But it is not in the Popup of Nios-ii Eclispe Editor. Thank you, oneplusone
