6240 Discussions
No CFI table found at address on Stratix IV GX development kit
Development kit: Stratix IV GX FPGA Development Kit (RoHS), 530 Edition f
FPGA: EP4SGX530KH40C4
Quartus version: 11.1 SP2
OS: Debian
I accidentally rewrote flash memory of Stratix 4 GX development kit and trying to restore it to default board update portal, according to User Guide.
I changed all dip switches to factory one.
I uploaded SOF image s4gx530_fpga_bup.sof, using both programmer GUI from quartus and programmer CLI (using command nios2-configure-sof).
When I'm trying to reprogram flash memory with command (bash ./restore.sh) and writing "r", I'm receiving following error:
nios2-flash-programmer -b 0x08000000 restore_s4gx530_fpga_bup.flash
Using cable "USB-Blaster [1-2]", device 1, instance 0x00
Resetting and pausing target processor: OK
No CFI table found at address 0x08000000
Leaving target processor paused
Note: the board FPGA should be configured as described
in the User's Guide, chapter entitled:
"Restoring the Flash Device with the Factory Settings"
Done.
I tried using different version of quartus 2 (11.1 sp2, 11.1), quartus prime (15.1, 16.1) and programmer, but nothing really changes this error.
Can you help me out with pointing what should I be looking for?
Hello Pogasanov,
Did you solve the issue?
Hello , I have a same problem with you.But the board is different: it is a cyclone v gx board . Do you solve the problem now ?
