Hi All,
I have an Arria II GX dev. kit and I use the Chaining DMA Design Example. I would like to implement advanced error reporting and ECRC forwarding. In the PCIe Compiler User Guide 9.0 (page 7-8), We can read this : The design example exercises the optional ECRC module when targeting the hard IP implementation using a variation with both implement advanced error reporting and ECRC forwarding set to On. If I set these options in the MegaWizard Plug-In Manager, the compilation process can not generate the sof file. Warning message : Can't generate programming files for project because design file […] is encrypted. It does not have license file support that allows generation of programming files. I use Quartus II 9.0 SP2 with a full version license. Has anyone else had a similar problem? What can I do for generate the sof file? Thanks SteveLink Copied
