Community
cancel
Showing results for
Search instead for
Did you mean:
zangman
[Noob DE10-nano] Can I deploy a generic rbf from linux using Cyclone V SoC?
Jump to solution
Hi - I'm a hobbyist new to the world of FPGA and especially FPGA SoC. I just got the DE10-Nano Rev C and I've been able to play around with the Linux installation and tried a few of the demo applications that came with it (SDCard image from here). I've also been able to use the USB Blaster and program a few designs directly on the FPGA (Blink, HDMI demo, simple cpu design) and both work just fine.
My questions are:
Question 1
Suppose I have a hello world blinking FPGA design for which I have generated the .sof file and confirmed it works, is there any way for me to take this file (or the .rbf file) and program the FPGA directly from Linux? The way I imagine it working is:
  1. Boot up Linux
  2. SSH into the de10-nano.
  3. SCP the blink design file to some location on the de10-nano
  4. ???
  5. LED starts blinking.
Is this possible? I have seen some sites online which say you have to copy it to /media/FAT and then reboot, but when I tried that it died and I had to reimage the sd card.
Question 2
I saw this video where he creates an HPS image from scratch and then writes a C program to control the LEDs. Would I have to do something like this every time I want to have a custom FPGA design that I want to interface with on the HPS? For example, if I have a custom image processing or machine learning algorithm implemented in verilog, is this the route I will need to take to be able to write a C program that can interact with the FPGA?
Thanks in advance and I apologise for the basic questions. I don't have anyone I can consult with :(.
Tags (1)
zangman
Okay I think I figured out how to deploy a generic hardware design to the FPGA. It doesn't really need device trees or configuring the Avalon bus, but it does need a specific linux image.
Here are the steps. First the hardware design:
  1. Create a simple FPGA only design in Quartus Prime. I used Quartus Prime Lite Edition 20.1. Here is my blinking LED:
    module blink (
      input clk,
      output led
      reg [27:0] counter;
      always @(posedge clk) begin
        counter <= counter + 1'b1;
      end
      assign led = counter[26];
    endmodule
  2. Assign the pins using the pin planner. I used `PIN_W15` with 3.3V LVTTL.
  3. Run the Assembler in Quartus. It will generate the sof in the output_files folder.
  4. Convert the sof to rbf using File > Convert Programming File. This will open a new window.
  5. Under 'Programming File Type', select 'Raw Binary (.rbf)'
  6. Under 'Mode', select 'Passive Parallel x16'.
  7. Name the output file `soc_system.rbf`.
  8. In the Input files section, click on SOF Data and click on 'Add File'. Select the sof file. In my case it was at `output_files/blink.sof`.
  9. Click Generate and close the window.
Here is a screenshot:
On the software side, to deploy this from the HPS, you need to use the console only version of Linux ("Linux Console (kernel 4.5)"). This can be downloaded from the Terasic website.
The reason you can't use the LXDE version is because it makes use of the HDMI output which is connected to the FPGA fabric and the hardware design should be able to work with it. It will still flash the rbf, but linux won't boot.
After writing the console version of the image to the SD card, copy the file soc_system.rbf into the fat partition (where the zImage file is also present).
Next, set the MSEL bits on the DE10-Nano all to on. This is needed for the "Passive Parallel x16" mode that we used.
Now when you insert the sd card and power it on, the design gets flashed and the FPGA fabric now implements your design.
To change the design from Linux, you can scp the new design to the de10-nano, mount the fat partition (which should be /mnt/mmcblk0p1) and replace the soc_system.rbf file there. After that reboot it and it should flash the new design.
This approach can be followed for more complex designs also which use the Avalon bus to interact between the HPS and the FPGA.
Hi ,
There are different possible ways for programming the FPGA which are mentioned in the below post
https://rocketboards.org/foswiki/Documentation/GSRD131ProgrammingFPGA
The rocketboards is worth exploring if you are getting started with FPGA. The forums  cover a variety of topics , including HPS , FPGA , DE10 , Cyclone V etc.
Thanks and Regards
Anil
Hi ,
Please let us know that whether
link was helpful.
Thanks and Regards
Anil
zangman
Hi Anil - Thanks for your reply. Yes, that link helps thank you!
I think I didn't really understand how SoCs work and the resources at rocketboard are very helpful.
Effectively, I think the steps are (please correct me if I'm wrong):
  1. Download the Golden Hardware Reference Design (GHRD)
  2. Customise it in Platform Designer
  3. Build the devicetree overlay
  4. Generate the rbf file
  5. Create bootable hard disk using u-boot and copy the rbf into the sd card.
  6. Write C program that will run on the HPS and interact with the FPGA
I confess, there is still a lot for me to understand here so I may be wrong on these points. I will need to spend some more time on the docs on rocketboard.
Hi ,
The following thread and related links will be more specific to the steps to be followed for the overlay.
You can compare the steps which you are following with the ones discussed in the thread.
https://forum.rocketboards.org/t/load-fpga-rbf-from-device-tree-overlay-example/999/22
Hope this helps.
Thanks and Regards
Anil
zangman
    module blink (
      input clk,
      output led
      reg [27:0] counter;
      end
    endmodule
Hi ,
Thanks for sharing your learning with the community.
Thanks and Regards
Anil
