Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Not able to display on NIOS II dev kit
I have a NOIS II developpement Kit. I have open the mandelbrot demo. then re-generate the system with SOPC builder (I dont'know why there was not generated). I load the board with the .sof.
I have write this program with NIOS IDE : (it should draw a blue screen with the text "hello world" on the lcd screen)
# include <stdio.h># include <io.h># include "system.h"# include "altera_avalon_pio_regs.h"# include <stdlib.h> # include "alt_video_display.h"# include "alt_tpo_lcd.h"# include "altera_avalon_sgdma.h"# include "altera_avalon_sgdma_descriptor.h"# include "alt_tpo_lcd.h"# include "simple_graphics.h"
static void drawMenuBackground(int horiz_start, int vert_start, int horiz_end, int vert_end, alt_video_display * display)
unsigned int colour;
unsigned int red, green, blue;
float increment;
unsigned int counter = 0;
blue = 0xFF;
red = 0;
green = 0;
increment = 255 / ((float)(vert_end - vert_start));
while (vert_start <= vert_end)
colour = (red<<16) | (green<<8) | blue;
vid_draw_line(horiz_start, vert_start, horiz_end, vert_start, 1, colour, display);
counter++;
red = (unsigned int)(increment * counter);
green = (unsigned int)(increment * counter);
vert_start++;
void rotate_frame_buffers(alt_video_display * display)
while(alt_video_display_buffer_is_available(display) != 0)
alt_video_display_register_written_buffer(display);
int main()
alt_tpo_lcd s_lcd;
alt_tpo_lcd *lcd = &s_lcd;
int result;
alt_video_display * display;
lcd->scen_pio = LCD_I2C_CS_BASE;
lcd->scl_pio = LCD_I2C_SCL_BASE;
lcd->sda_pio = LCD_I2C_DAT_BASE;
display = alt_video_display_init( LCD_SGDMA_NAME,
800,
480,
32,
ALT_VIDEO_DISPLAY_USE_HEAP,
2);
result = alt_tpo_lcd_init(lcd, 800, 480);
if(!result) {
printf("LCD control registers initilized\n");
} else {
printf("LCD control register initialization failed\n");
char Text[] = "Hello world";
drawMenuBackground(0, 0, 799, 479, display);
vid_print_string_alpha(130, 50, RED_24, CLEAR_BACKGROUND, timesnewroman_24, display, Text);
rotate_frame_buffers(display);
return 0;
All is compiled and loaded successfully to the board but nothing works and I don't know why !!
If someone can help
