On my project I have this component:
typedef ihc::mm_master<unsigned char, ihc::aspace<1>,
ihc::awidth<32>,
ihc::dwidth<8> > Master1;
typedef ihc::mm_master<unsigned char, ihc::aspace<2>,
ihc::awidth<32>,
ihc::dwidth<8> > Master2;
hls_avalon_slave_component
component void imgOffSet(Master1& imgIn,
Master2& imgOut,
hls_avalon_slave_register_argument int N) {
for(int y=0; y < N; y++){
#pragma unroll 8
for (int x=0; x < N; x++){
int px = pxToMem(x,y,N);
printf("%d \n", px);
unsigned int tpx = ((unsigned int) imgIn[px])+OFFSET;
if(tpx > 255)
imgOut[px]= 255;
else
imgOut[px]= tpx;
The problem is that the HLS creates two conduits that is the base address of ImgIn and ImgOut, I would like to have this address on the already existent CSR register, that is accessible by the Slave port created by the compiler, as shown bellow:
- Tags:
- Hls
You can refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/mnl-hls-reference.pdf in Chapter 4.3.2 with explicit example.
There is an avalon standardize interface format that need to follow
You may try to change the code code as below:
component void imgOffSet(hls_avalon_slave_register_argument Master1& imgIn,
hls_avalon_slave_register_argument Master2& imgOut,
