5784 Discussions
On the Arria 10 GX FPGA Development kit I am able to load the qts_pcie.sof using the "Arria10 FPGA Board Test System" (BTS) application, but afterwards it is not recognized by the BTS. Also I can not find it in Windows 10 or Linux.
BStui2
Infact none of the examples, except for the BUP design, are recognized by the BTS after loading. Why is that?
Also, after loading the PCIe design and a soft-reset, I can not find the board in Windows 10 (device manager) or Linux (lspci). The board doesn't even show up in the BIOS "Board Explorer". Meanwhile my other FPGA development boards will show up there..
So far I have been following the instructions from AN-456-2.5.
SengKok_L_Intel
Hi
The AN456-2.5 should work. Alternatively, you can follow the user guide below to generate the design example from PCIe IP guide for A10 devkit. We have tested it and it works well.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-a10-pcie-avst.pdf
Regards -SK
BStui2
Hi SK,
Thanks, I was successfully able to build and run the PCIe design from the UG (ug-dex-a10-pcie-avst.pdf) that you have send me.
At least now I know the hardware (or at least the parts I need) is working.
Thanks!
SengKok_L_Intel
This is glad to know that.
Regards -SK
