6269 Discussions
PCI Express High-Performance Reference Design in Cyclone IV GX Devices
hi
I'm trying to download "PCI Express High-Performance Reference Design in Cyclone IV GX Devices" from this link:
https://www.altera.com/support/refdesigns/ip/interface/pcie_civgx_avst_on_chip_mem_140.zip
but i receive "Page not founed" error (error404). I found this link in "PCI Express High Performance Reference Design" pdf and I downloaded this pdf from altera site.
please help me to find another link of this zip file or please upload it for me if you have it.
This may help
· http://www.alterawiki.com/wiki/category:pci_express
Also
Ref Design Zip Files: https://www.altera.com/support/support-resources/intellectual-property/interface-protocols/pci-express/m-pci-express-refdesigns.html
For the Cyclone V, please go down to the “PCIe With On-Chip Memory Interface Reference Designs” section (link below) and go down to the third one, for Cyclone V GT. That is the same as the one in the link on Page 11 of AN456.pdf.
Best Regards, Bob.
PS: I am trying to get the Cyclone IV Transciever Starter Kit working with this GUI example ..the card is seen, and enumerated but the GUI doesn't have any of the tests active ... any ideas on how to get the GUI to run with it ?
Thanks, Bob.
Also, can anyone comment on then these examples indicate Quartus 14.0 ... is that a pre-requisite to build / compile ?
I am at 13.1 for stability reasons ... I can switch to 14.0 for testing ... but would like to know if it is necessary ?
Thanks, Bob.
--- Quote Start ---
hi
--- Quote End ---
You can get the PCIe reference design for CIV GX dev kit from this link:
https://www.altera.com/support/support-resources/software/download/refdesigns/ip/interface/dnl-pciexpress-hp.html
--- Quote Start ---
Thanks, Bob.
--- Quote End ---
Hi Bob,
This is indicating that these example designs are created and verified with Quartus 14.0. Thus, it is recommended for you to use 14.0 to ensure compatibility and expected behavior of the designs.
From Quartus II 13.1 to 14.0, there is a major change from Megawizard to IP Editor for IPs instantiation. You might not be able to compile the 14.0 generated design in 13.1.
