Hi i'am initially making pin assignment in cyclone v , when i try to build an top module (with just pin's) and try to synthesize with few modules its getting compiled and synthesized, but when i add pcie hard ip pin's in device, with integrated two hard ip's the synthesis is not passing, can any one help me out to solve this issue.
Pavan
Dear Nathan,
Many thank's for the link's which you have sent.
Actually We are in the initial stage of project were we need to share ".pin" file to Board team.
When we try to do assignment with early pin planning for PCIE we are facing the issue related to compilation .
When we assign other pins we don't have issue.
Can you help us on this ?
Thanks and regards
Pavan Kumar
Hi Nathan,
Thanks for the links and information regarding channels.
1.We are planning to use X1 and X2 for two PCIe Endpoints.
2.Can we generate a IP with X2 lane support and instantiate them and keep the one of the lane unused .
3. Following are the pin assignments we are planning to use .
Bank Number | Location |
GXB_L2 GXB_TX_L7n M3 PCIE _EP1_TX[1]_N
GXB_L2 GXB_TX_L7p M4 PCIE _EP1_TX[1]_P
GXB_L2 GXB_Rx_L7n N1 PCIE _EP1_RX[1]_N
GXB_L2 GXB_RX_L7p N2 PCIE _EP1_RX[1]_P
GXB_L2 GXB_TX_L6n P3 PCIE _EP1_TX[0]_N
GXB_L2 GXB_TX_L6p P4 PCIE _EP1_TX[0]_P
GXB_L2 GXB_Rx_L6n R1 PCIE _EP1_RX[0]_N
GXB_L2 GXB_RX_L6p R2 PCIE _EP1_RX[0_P
GXB_L2 REFCLK2Lp P8 PCIE _EP1_REFCLK_N
GXB_L2 REFCLK2Ln N7 PCIE _EP1_REFCLK_P
Pavan
Adding one more query is it possible to assign only IO's for PCIE HARD IP and do Analysis to generate the ".pin" file for the board team.
When we try the above step we are getting the compilation error as below
Error (177035): The input pin PCI_EP0_REFCLK_P assigned to HSSI Pin_W8 has no fanout.
Error (177035): The input pin PCI_EP0_REFCLK_N assigned to HSSI Pin_W7 has no fanout.
Error (177035): The input pin PCI_EP0_RX_P[0] assigned to HSSI Pin_AG2 has no fanout.
Error (177035): The input pin PCI_EP0_RX_P[1] assigned to HSSI Pin_AE2 has no fanout.
Error (177035): The input pin PCI_EP0_RX_N[0] assigned to HSSI Pin_AG1 has no fanout.
Error (177035): The input pin PCI_EP0_RX_N[1] assigned to HSSI Pin_AE1 has no fanout.
Error (177035): The input pin PCI_EP1_REFCLK_P assigned to HSSI Pin_N7 has no fanout.
Error (177035): The input pin PCI_EP1_REFCLK_N assigned to HSSI Pin_P8 has no fanout.
Error (177035): The input pin PCI_EP1_RX_P[0] assigned to HSSI Pin_R2 has no fanout.
Error (177035): The input pin PCI_EP1_RX_P[1] assigned to HSSI Pin_N2 has no fanout.
Error (177035): The input pin PCI_EP1_RX_N[0] assigned to HSSI Pin_R1 has no fanout.
Error (177035): The input pin PCI_EP1_RX_N[1] assigned to HSSI Pin_N1 has no fanout.
Error (11802): Can't fit design in device. Modify your design to reduce resources, or choose a larger device. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Error: Quartus Prime I/O Assignment Analysis was unsuccessful. 13 errors, 13 warnings
Error: Peak virtual memory: 5625 megabytes
Error: Processing ended: Tue May 07 17:54:45 2019
Error: Elapsed time: 00:00:16
Error: Total CPU time (on all processors): 00:00:16
Dear Nathan,
Thank you so much for your valuable time and links, i will check them, if i get doubt's i will let you know.
Best Regard's
Pavan
@lakshmi.narayanan@blackpeppertech.com @vedashri.parashivamurthy@blackpeppertech.com
Hi Nathan,
As i have assigned top(EP1) with x1 lane and bottom(EP0) with x2 lane.
currently there is no design , only top file with I/O's.
EP1
EP0
GXB_TX_L1n AD3 PCI_EP0_TX_N[1]
GXB_TX_L1p AD4 PCI_EP0_TX_P[1]
GXB_RX_L1p,GXB_REFCLK_L1p AE2 PCI_EP0_RX_N[1]
GXB_RX_L1n,GXB_REFCLK_L1n AE1 PCI_EP0_RX_P[1]
GXB_TX_L0p AF4 PCI_EP0_TX_P[1]
GXB_TX_L0n AF3 PCI_EP0_TX_N[0]
GXB_RX_L0p,GXB_REFCLK_L0p AG2 PCI_EP0_RX_N[0]
GXB_RX_L0n,GXB_REFCLK_L0n AG1 PCI_EP0_RX_P[0]
REFCLK0Lp W8 PCI_EP0_REFCLK_P
REFCLK0Ln W7 PCI_EP0_REFCLK_N
Thanks and Regards
Pavan
