Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
[PCIe Dev board] Established GiGe link with marvell 88e1111
I have a pci express dev board and i would to make a giga ethernet connection with the marvell 88e1111 PHY transceiver (in copper mode).
I have successfully instantiate tse mac block in stratixII device and i have build logic around for configuration.
MAC loopback mode and also PHY loopback mode run successfully.
But when i desactive all loopback mode and i try to established a link with network card on my pc, nothing happens...
After configuration sequence of tse mac block, i make a reset of the marvell PHY (with the respect of all reset timing specifications find in the 88e1111 datasheet). for now, i didn't change nothing in internal registers of the marvell PHY. Hardware configuration (CONFIG[6..0]) are good for gigabit operation and auto negociation.
What can i make to link pcie board and network pc card ?
Must I send a specific mac frame just to link cards ?
Could someone help me and tell me the exact registers configuration of the mac block or the good procedure ?
Any help will be appreciate.
Thanks in advance!
Highlighted
Hi, I actually have a similar problem with the TSE. I use the TSE reference design, but I can't make the TSE running with a PHY LOOP BACK. How did you manage to do that?
Thanks for your help,
Celine
