When the customer connect USB cable to EK-10M08E144, red LEDs turned on continuously. Per datasheet, When powered correctly, a pre-programmed design blinks LEDs D1 through D5 ON half a second then OFF half a second. Is this product out of order? or how should the customer proceed? please help to advise. Thank you. Dan.lee@mouser.com
Hi Dunn,
Board is pre-programmed with different design.
MAX 10 FPGA (10M0S, 144-EQFP) Evaluaion Kit User Guide is not been updated,The pre-programmed design is connection between SW3 (1 - 5) and led (D1 - D5).
You can change SW3 state to see the difference.
Sorry for the inconveniences caused.
Anand
For more complete information about compiler optimizations, see our Optimization Notice.
