5779 Discussions
Pin assignment for Flash and SDRAM of DE2-70
Dear my friends
I wanna make pin assignments for flash and Sdram of DE2-70 altera kit but I don't know which one is correct. Could you check it for me (I've attached it in this message)?
what is the pin
"select_n_to_the_cfi_flash_0"?
"tri_state_bridge_0_readn"?
"write_n_to_the_cfi_flash_0"?
Thank you very much
"select_n_to_the_cfi_flash_0" : FLASH_CE_N pin AG28
"tri_state_bridge_0_readn" : FLASH_OE_N pin AG29
"write_n_to_the_cfi_flash_0" : FLASH_WE_N pin AJ29
--- Quote Start ---
--- Quote End ---
Thank you very much. I got it. I try it now, if I have any problem could I ask again?
Best regards
After compiling and downloading to FPGA, I'd run NIOS II and got this error. How can I fix this error?
--- Quote Start ---
**** Build of configuration Release for project Homwork ****
make -s all includes
1 [main] ? (6404) c:\altera\90\quartus\bin\cygwin\bin\sh.exe: *** fatal error - couldn't allocate heap, Win32 error 487, base 0x680000, top 0x690000, reserve_size 61440, allocsize 65536, page_const 4096
0 [main] sh 3916 fork: child -1 - died waiting for longjmp before initialization, retry 0, exit code 0x100, errno 11
/bin/sh: fork: Resource temporarily unavailable
/bin/sh: /cygdrive/c/altera/90/nios2eds: is a directory
cygpath: can't convert empty path
/cygdrive/c/altera/90/nios2eds/components/altera_hal/build/system_rules.mk:120: /components/altera_hal/build/gnu_rules.mk: No such file or directory
/cygdrive/c/altera/90/nios2eds/components/altera_hal/build/system_rules.mk:124: /components/altera_hal/build/gtf_rules.mk: No such file or directory
make[1]: *** No rule to make target `/components/altera_hal/build/gtf_rules.mk'. Stop.
make: *** [system_project] Error 2
Build completed in 5.478 seconds
--- Quote End ---
Which version of Quartus are you using? IIRC this is a common problem with Cygwin. If you search the forum with cygwin, fork and/or "couldn't allocate head" you should have some answers.
--- Quote Start ---
--- Quote End ---
I used Quartus II 9.0
Yes I think it was a very common problem with Quatrus II 9.0. I don't remember if there was a fix though.
