I am trying to work through the DDR2 SDRAM tutorial for Cyclone III found in the External Memory Interfaces Handbook:
http://www.altera.com/literature/lit-external-memory-interface.jsp I have a Cyclone III development kit and this tutorial is targeted for this board. The tutorial is in Volume 6, Section I, Chapter 6 - "Using High-Performance DDR, DDR2, and DDR3 SDRAM with SOPC Builder". Page 6-26 refers to an Altera-provided pin assignment file "C3_Dev_DDR2_Sopc_Pin_Location.tcl". I cannot locate this file anywhere. Can someone point me to this file or any documentation that will give me the proper pin assignments? This file is also referred to in the documentation on this design example page: http://www.altera.com/support/examples/verilog/ver-cyclone-iii-36-bit-ddr2-altmemphy.html There is a zip file to download on this page that contains the file "CIII_DDR2.qar" but it is some kind of non-text file - I'm assuming it is an archive file. Would the pin assignment file that I'm looking for be in that? If so, how do I open it? I'm new at this.Link Copied
I am now facing the problem that you are facing looking for the tcl file C3_Dev_DDR2_Sopc_Pin_Location.tcl, did you ever find it? Thanks- Mark as New
I filed a service request on this and was directed to a different project that did contain the file:
http://www.altera.com/support/examples/verilog/ver-cyclone-iii-8-bit-ddr2-altmemphy-sopc.html They also sent me a copy of the file which is attached here. The extension for the file is .tcl but I made it a .txt file to post here, so remove the .txt extension from the filename if necessary.- Mark as New
thank you so much!
