5781 Discussions
Pls can yuo help me with FA for Intel part number 5SGXMA7N2F45I3N
PPere22
Please private message for more details.
Zawani_M_Intel
Thank you for contacting Intel Community.
Please be noted that Intel FPGA requires details information for failure analysis request. Please help to answer questions below in order for us to better understand your position.
1. Please provide full device details.
1.1. Device name : Stratix V
1.2. Full part number: 5SGXMA7N2F45I3N
2. What is the failure symptom? Please elaborate the failure symptom in detail.
5. When did the failure happen? How did you discover the failure?
6. How did you determine the failure? Please elaborate the procedures.
7. Does the failure unit ever working before failure?
8. Did they violate solder re-flow temperature profiles, moisture sensitivity? Please provide the re-flow temperature profiles.
9. Did you swap the failure device to a known good board? Is the failure following the device or board?
-Wani-
Zawani_M_Intel
Hi PPere22, Is there any update for this request? Thanks! -Wani-
Zawani_M_Intel
Hi PPere22,
Generally we could not let the case without activity for long time.
I will close the case.
Please do let me know if you have any concern.
Thanks!
Wani
