6314 Discussions
Power failure pointed to this EP4CGX50CF2317N
SOtha1
Encountered power failure in field and customer wanted request FA on the faulty device.  Please help to review and provide ERMA #.
Failed: Field failure (RMA return)
Failure :
SN ACPZ9396---Unable to power up port – DC :1613
SN ACPG6599—Unable on line(Power failure) – DC 1537
MPN : EP4CGX50CF2317N
PN : JNTG-310-053350
Qty for FA : 2 pcs
Supplier : Altera.
Desc: Altera Cyclone EPACGX50CF23I7N FPGA
(Virus scan in progress ...)
Zawani_M_Intel
Do you suspect any failed pins? If yes, can you listed the pin name here?
Wania
SOtha1
Failed part removed and no specific pin was suspected failing .
The failed board has been isolated, passed after replacement with new EP4CGX50CF2317N.
Hence, customer want this unit to send back to Intel for further FA.  Please help to share the ERMA #.
SOtha1
Hi Wani,
Any update on this?
We seek your prompt respond here since Juniper is now chasing for the FA result. This failure observed on our RMA board, return from field and wanted to understand the failure root cause.  Please help to look into thus request and provide the ERMA # accordingly.
SOtha1
Hi Zawani,
Kindly support on this FA request asap. Your prompt support is required for this case.
SOtha1
Hi Zawani,
Can we know what is the stopper for you to handle this case? We have been waiting for long time.
If there are any other thing that you need us to provide, please let us know.  We will consult with Juniper for this.
Zawani_M_Intel
Hi ,
The case previously was unavailable due to has been closed by the third party. I re-open back the case and an email has been sent to you to proceed for further step. We will continue the communication through forum email as I required some confidential info.
Wani
