6345 Discussions
Power up the device(CYCLONE 5) in temperature under zero
sn681
we are using in our board the device CYCLONE 5 - 5CSEBA5U23,
when we are trying to power up the device in temperature under zero( -5 cel),
we are getting the " altera_load" failed with error code -2" and the "conf_done" stays low.
If the board is power up in a positive temperature , and we are cooling the board, the device working fine.
We check all signals control , the are setting ok.
NurAiman_M_Intel
Have you follow our userguide when configuring and power up the FPGA?
https://www.intel.com/content/www/us/en/docs/programmable/683375/current/logic-array-blocks-and-adaptive-logic-24877.html
Aiman
sn681
Hi Aiman,
We designed our board according to Intel's recommendation.
The device works great in all temperatures, but when we trying to turn it on at temperatures below zero
we are getting the " altera_load" failed with error code -2".
Is there anything we can try to resolve this ?
NurAiman_M_Intel
Thank you for the update. Can you provide us the screenshot of the failure/error code?
Aiman
NurAiman_M_Intel
Also, please provide the full device OPN.
NurAiman_M_Intel
If you ae using commercial device, the operating junction temperature should be between 0 to 85C.
sn681
1. I have attached a screenshot of the error code.
2. what do you mean when you wrote "full devic OPN"?
3.We use CYCLONE V - 5CSEBA5U23I7N, the operating junction temperature should be between -40 to 100C.
(Virus scan in progress ...)
NurAiman_M_Intel
-How many devices show the same failure when power up using below 0cel?
-Please share the top marking for the failing devices.
Aiman
sn681
 Hi Aiman,
- We tested 10 devices and 8 of them showed an failure when power up  below 0cel.
-You want me to share the top marking of the CYCLONE V - 5CSEBA5U23?
sn681
Hi Aiman,
Is there any update?
sn681
Hi Aiman,
See attached top marking of the CYCLONE V - 5CSEBA5U23.
NurAiman_M_Intel
Apologize for the delay in response.
Can you check:
  • Power up status such as
  • power rails all power up correctly
  • Measure the voltage during the power up
  • Also, different component on the board can also effect the power up
  • And, is there any changes when power up between those 10 devices? Are the 10 devices using the same board or different board?
Aiman
sn681
Hi Aiman,
-We check all power rails there is no change when power up below 0cel.
-We measure the voltage during the power up, the are setting ok.
-The signal "conf_done" stays low.
-There are no different components between the boards, the 10 devices using the same board.
NurAiman_M_Intel
Per my discussion with internal team, we will need to proceed this for FACR.
May I know your location and company?
Aiman
sn681
Hi Aiman,
Vectria Technologies located at Ashkelon Israel.
NurAiman_M_Intel
Thanks for the information. Our FA team will contact you soon.
Aiman
sn681
Hi ,
Thanks, waiting for contact.
NurAiman_M_Intel
Can you help to provide who is the end customer? And also provide #SO/#PO?
Aiman
NurAiman_M_Intel
Do you have the information for the end customer and the #SO/#PO?
Aiman
NurAiman_M_Intel
May I know if there is any update for the request?
Aiman
sn681
Hi Aiman,
Sorry for the late reply.
The final product is ours and sold to several different customers.
#PO - BL20002230.
