6367 Discussions
Problem when I try to simulate pcie_avmm_dma example design for Cylone 10GX
AKARP2
When I run tcl scripts they can't find file
pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_191_nz2pxji.sv.
Please, advice
Thank you
SengKok_L_Intel
Are you run the simulation by using the IP generated example design?
Did you go to the "../*_tb/*_tb/sim/mentor/" folder to run the simulation script?
What is the simulation tool that you are using (Modelsim Intel FPGA, VCS or..)?
Regards -SK
AKARP2
Yes
Yes
ModelSim 10.6d starter
Thank you for replay
Regards, Alex
SengKok_L_Intel
Hi Alex,
I’m using the following steps but does not see the error:
  1. Generate the PCIe avmm DMA example design from PCIe IP GUI by using Quartus 19.1 pro
  2. Open modelsim 10.6d, and change the directory to “ xxx_example_design/xxx_example_design_tb/ xxx_example_design_tb/sim/mentor”
  3. Source msim_setup.tcl
  4. Type ld_debug in Transcript
  5. Add waveform
  6. Type run -all in transcript
Regards -SK
AKARP2
I'm using the same sequence as you.
I am working with Quartus Prime Pro 19.2, system - Windows 10
In “ xxx_example_design/xxx_example_design_tb/ ip/xxx_example_design_tb/xxx_example_design_tb/
pcie_example_design_inst_board_pins_bfm_ip/sim/common/modelsim_files”
you can find line:
lappend design_files "vlog -sv $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS \"[normalize_path "$QSYS_SIMDIR/../altera_conduit_bfm_191/sim/pcie_example_design_inst_board_pins_bfm_ip_altera_conduit_bfm_191_nz2pxji.sv"]\" -L altera_common_sv_packages -work altera_conduit_bfm_191"
And this file is absent in this directory.
Can you send it to me?
e-mail alex.karpel@cmt-med.com
Thank you, Alex
SengKok_L_Intel
Hi Alex,
I'm not seeing the same error as you. But I encountered another problem when I almost finish running the simulation. It is somehow stopped with a Fatal Error. There is no solution at this moment, and this is tentatively targetted to fix in the next software release. There is a plan to release a KDB solution for this case.
I apologize for the inconvenience caused.
Regards -SK
AKARP2
Thank you.
I will wait for update.
Alex
SengKok_L_Intel
Hi Alex,
FYI. Arria 10 Gen2 mode is having the same fatal error, however, Arria 10 Gen 3 mode is working fine in the simulation.
Regards -SK
SengKok_L_Intel
FYI. I have just tested the Cyclone 10 GX PCIe AVMM DMA simulation in Quartus Prime version 19.4, it works well with ModelSim SE.
Regards -SK
