5922 Discussions
Problem with GPIO port altera board
SImen
Hello all,
I'm using the altera board. I'm implementing a new system based on the Computer system project provided with the board. I added new PIO modules in Qsys and performed generation and instantiation of the module. I wanted to send data via the GPIO_0 port. It worked well before , so i could visualize some signals on the oscilloscope.
But the problem now is that new GPIO_0 signals i created seem to be not working , even if i send a 'high' permanent signal i cannot see it on the oscilloscope. I generated the new system and compiled several times.
Please could you give me some advice on how to solve this out
Best regards
EBERLAZARE_I_Intel
May I know which Quartus Version you are using? Also, which board are you currently working on?
I recommend that you read our user guide on the PIO IP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf#page=297
Regards.
SImen
Hi , thank you so much for your reply
I finally found that the problem was with licensing of some FPGA IP cores , a time limited sof file was generated that caused the problem
since i was downloading the old sof programming file
Is there a way to get an unlimited version with the quartus prime lite version
regards
EBERLAZARE_I_Intel
Our Quartus Prime Lite Version is available as a free download with no license file required.
Regards.
EBERLAZARE_I_Intel
Do you have additional questions?
Best Regards.
