Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Problem with "Multiple server sockets"
I am having a problem with 2 TCP server sockets on my STRATIX II kit.
I have defined 2 server sockets listening on 2 different ports called:
"control server" task priority 6
"telnet server" task priority 7
see attached "Startup Sequence" below.
My problem is that I cannot connect as a "telnet client" before a "control client" has been connected (the highest priority). I don't know if I have to modify some NicheStack header file or modify an interrupt routine so any kind of help would be appreciated from anybody familiar with "Multiple server sockets" handling. Both my server tasks has a usleep(20000) - 20ms to avoid task blocking.
Startup Sequence:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
Static IP Address is 10.0.0.101
prepped 1 interface, initializing...
Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
smsc91c111 Auto-negotiation: 10 Mbps, Half Duplex
SMSC ethernet Rev: 0x3391, ram: 8192
mctest init called
IP address of et1 : 10.0.0.101
Created "control server" task (Prio: 6)
Created "telnet server" task (Prio: 7)
[ControlServerTask] listening on port: 10008
[TelnetServerTask] listening on port: 23
[ControlServerAccept] accepted connection request from 10.0.0.100
[TelnetServerAccept] accepted connection request from 10.0.0.100
I think you'd have to use the preferred iniche call, TK_SLEEP(), or the similar uC-OSII function. I don't believe the built-in usleep() call does anything OS-related.
Cheers,
- slacker
It's not an Interniche issue. It has to be the way your program is written. I believe the uCOSII call is TK_YIELD().
Jake
I agree that usleep shouldn't be used. You can either use the suggested macros, or the OS call OSTimeDelay.
I had a similar kind of problem when using two tasks that opened two different sockets. I could open socket A and socket B, but afterwards if I closed socket A, I couldn't communicate on socket B until I reopened socket A. I solved the problem by uncommenting the
#define TCPWAKE_RTOS 1line in ipport.h
