6400 Discussions
Problem with reading register of deo nano's accelerometer
Hello everyone,
I am using deo nano and am trying to read the register of its accelerometer via I2C.
I have used the same program to read a value from eeprom register and it works out well.
But using the same program, I cannot get acknowledge signal at the moment I sent the device address(accelerometer). I have checked my timing diagram and have generated a slower clock that pass with accelerometer. I also use signaltap2 to check out the value of my internal register.
Here is the syntax:
// ADXL clock= 400kHz or 2.5uS or 125 samples of 50mHz.
// ADXL address= 0x53/1010011 (alt address pin grounded)
module ADXL_Read(
clk_50, //clock 50Mhz//
key,
I2C_sclk,
I2C_sdat,
input clk_50;
input [1:0] key;
output I2C_sclk;
inout I2C_sdat;
wire reset_n;
reg GO;
reg sdi;
reg sclk;
reg [6:0] count; // Create slower clock with 128 samples of 50Mhz
reg [6:0] sd_counter;
reg [6:0] slave_add = 1010011; // DEFINE SLAVE ADDRESS
reg [7:0] register_add = 00110010; // DEFINE REGISTER ADDRESS
reg [7:0] data; //Data that is read
assign reset_n= key[0];
// 50MHz clock is too fast for the our devive(in this case eeprom),
// therefore slower clk need to be generated
always@(posedge clk_50) count <= count + 1;
// key[0] is to reset the whole operation
// key[1] is to give a start signal
always@(posedge count[6] or negedge reset_n)
begin
if (!reset_n)
GO <= 0;
else
if (!key[1])
GO <= 1;
end
always@ (posedge count[6] or negedge reset_n)
begin
if(!reset_n)
sd_counter <= 6'b0;
else
begin
if (!GO)
sd_counter <= 0;
else
if (sd_counter < 52) //sd_counter maximum
sd_counter <= sd_counter + 1;
end
end
begin
if (!reset_n)
begin
sclk <= 1;
sdi <= 1;
end
else
case (sd_counter)
6'd0 : begin sdi<=1; sclk<=1;end
//START
6'd1 : sdi <= 0;
6'd2 : sclk <= 0;
//SLAVE ADDR+Write(Control Byte)
6'd3 : sdi <= slave_add[6];
6'd4 : sdi <= slave_add[5];
6'd5 : sdi <= slave_add[4];
6'd6 : sdi <= slave_add[3];
6'd7 : sdi <= slave_add[2];
6'd8 : sdi <= slave_add[1];
6'd9 : sdi <= slave_add[0];
6'd10 : sdi <= 0; //Write(0)
6'd11 : sdi <= 1'bz;//Slave ACK
//SUB ADDR(WORD ADDRESS)
6'd12 : sdi <= register_add[7];
6'd13 : sdi <= register_add[6];
6'd14 : sdi <= register_add[5];
6'd15 : sdi <= register_add[4];
6'd16 : sdi <= register_add[3];
6'd17 : sdi <= register_add[2];
6'd18 : sdi <= register_add[1];
6'd19 : sdi <= register_add[0];
6'd20 : sdi <= 1'bz;//Slave ACK
//START
6'd21 : begin sdi <= 1; sclk<=1; end
6'd22 : sdi <= 0;
//SLAVE ADDR+Read(CONTROL BYTE)
6'd23 : sdi <= slave_add[6];
6'd24 : sdi <= slave_add[5];
6'd25 : sdi <= slave_add[4];
6'd26 : sdi <= slave_add[3];
6'd27 : sdi <= slave_add[2];
6'd28 : sdi <= slave_add[1];
6'd29 : sdi <= slave_add[0];
6'd30 : sdi <= 1; //Read(1)
6'd31 : sdi <= 1'bz;//Slave ACK
//Data read(DATA)
//Data byte 1
6'd32 : data[7]= I2C_sdat;
6'd33 : data[6]= I2C_sdat;
6'd34 : data[5]= I2C_sdat;
6'd35 : data[4]= I2C_sdat;
6'd36 : data[3]= I2C_sdat;
6'd37 : data[2]= I2C_sdat;
6'd38 : data[1]= I2C_sdat;
6'd39 : data[0]= I2C_sdat;
6'd40 : sdi <= 1'b1;//Master ACK
//Data byte 2
6'd41 : data[7]= I2C_sdat;
6'd42 : data[6]= I2C_sdat;
6'd43 : data[5]= I2C_sdat;
6'd44 : data[4]= I2C_sdat;
6'd45 : data[3]= I2C_sdat;
6'd46 : data[2]= I2C_sdat;
6'd47 : data[1]= I2C_sdat;
6'd48 : data[0]= I2C_sdat;
//stop
6'd49 : begin sdi <= 1'b0; sclk <= 1'b1; end
6'd50 : sdi <= 1'b1;
endcase
end
assign I2C_sclk = (((sd_counter >= 4)&(sd_counter <= 20))|((sd_counter >=24)&(sd_counter <=50)))? ~count[6] : sclk;
assign I2C_sdat = sdi;
endmodule
Here are the pin planner assignment:
I2C_sclk : F2; I2C_sdat : F1 ; clk_50 : R8 ; key[1] : E1 ; key[0] : J15 ;
Here are the signaltap node(trigger cond): sd_counter(don't care), I2C_sclk(don't care), I2C_sdat(don't care), GO(Rising edge).
Signal configuration for signaltap2: clock(count[5]), sample depth(1k), storage qualifier(continuous), trigger(sequential, pretrigger position, 1)
Note: make the "bus display format" of node "sd_counter" to be "unsigned decimal" for the ease of viewing.
I realize the problem happen when sdat at 6'd3 until 6'd9. Although I assign slave_add to be 1010011, it appears at the signal tap to be 1011011
Why does it happen?
I realize it is too much to ask. Please someone help me find out the solution. I have stuck in this problem for the last 3 days and have yet no idea.
Thank you so much for helping me.
