5543 Discussions
Problem with tPad VIP Camera demonstrations
I have the tPad DE2-115 and I try to use the VIP Camera demonstration. After compilation of the hardware with the only changement in the reset of the nios (sram instead of flash). I programed the hardware in the board.
Then I wanted to use the software of the VIP Camera included in the demonstration folder. I created a Nios IDE project with the code. But the program crash and nothing good is printed on the board's screen.
It appears randomly that it works only when I launched the program in debug mode and run slowly step by step the code.
In the main function, the code seems to be executed until Mixer_init().
The problem seems to come from the mixer, but I'm not really sure. Somebody could help me?
I have Quartus II 10.1 and NIOS II SDT for Eclipse II 10.1.
Thank you,
If someone has the same problem. The solution is to change the section from the sdram to the sram in the bsp editor.
