I'm trying to connect the Intel Cyclone 10 GX device to PCIe. When I execute the command described in the Intel manual:
quartus_cvp --vid=<Vendor ID> --did=<Device ID> xxx.core.rbf
The terminal presents me the following error:
'quartus_cvp' is not recognized as an internal command
or external, an operable program or a batch file.
After further checking, it looks like quartus_cvp is no longer supported. Sorry for the inconvenience.
Could you try to restart your PC again and try to performed "cp <filename>.core.rbf /dev/altera_cvp"? I suspect that the PCIe link might be in used which cause the issue.
- « Previous
- 1
- 2
- Next »
Ok, and about the other question, Can you recommend me some material?
You may refer to https://www.intel.com/content/www/us/en/programmable/documentation/xtq1467072880606.html for the PCIe design example
John, thank you very much for your attention.
Tomorrow I going to study this material and any questions, get in touch.
Sure. Let me know if you have any more question.
- « Previous
- 1
- 2
- Next »
